pace setter high flows and true duals
Lets try this. I'm not saying anyone is wrong, I'm just stating what can and has been done, - understand ? So if you were to find a set cheap online, -say from a 5four/4six stang or whatnot, you could make them work. It's not that hard if your set up for it, or have a guy that is. It's another alternative. Like it or leave it.
jbrew youve helped me alot on this site just wanted to say thanks and to all others who have also helped... idk if i misread your message when you said dynatech are the best youl get nothing under your foot. did you mean with dynatech i wont get anything under my foot or what??? i am looking into hi flow magnaflows like you said.. another question wouldnt a xpipe be better than a y for the power issue??
Dis regard my post about that- I've been under the wrong impression about Dynatech and OBX I guess. Been out of the loop. It used to be Dynatech was more than just a name. I've read in the past on a few occasion that sound and heat inside the cab, from down under can be an issue with OBX systems. It could be that these individuals didn't install correctly.
I don't know how that can be true if both manufacturer use the same hardware. I can see why their cheeper in price, - the quality isn't takin a hit. It's cheaper for OBX to make a set . Which actually works in everyones favor that's in the market for set.
im running duals not single.. so beens im running duals i should run a x pipe to solve the power issue??? and does anyone have a link for a OBX header set that comes with everything you need excluding the cats?? does anyone have a link for a not so pricy dynatech header kit also??? i understand that the two are the same things but i like buyin american made and ivel also heard the welds on OBXs crack.. thanks guys
Outlawbred, I can't remember the users name, Texas something I think ? Idunno. Try looking up Dynatech Bassani install. This guy ran dual system , Bassani's on a lightning (Pretty sure). Awesome as hell pics, real clear and a step by step.
I'll look for it later when I more time, but yea, this is the site. It may be in the lightnings forum. Or google it lol.
Found it -
Yea, don't use the search bar on this site, it blows lol. - Google found it right away.
https://www.f150online.com/forums/ar...-2003-a-2.html
