Cool Air Intake and other stuff
Here is a post from Mike Troyer - Troyer Performance that explains it well:
Hi Trriton 2,
Exhaust is really outside of the realm of this section of the boards, so you really need to give us a call to go over this in proper detail.
Though it's not an absolute must, yes, we do recommend getting rid of the "Slowmaster" muffler and replacing it with an appropriate Magnaflow unit - that will help to improve torque. Now exactly which muffler you use will depend on what kind of sound characteristics you want, so that's why you need to call, so we can go over all of that with you. It's not just length alone, for example.
What that Flowmaster setup is doing is actually *reducing* torque on part throttle at any rpm, and reducing torque below about 3000 rpm a at any throttle position - and that is due to all those silly baffles & chambers they use as part of their "sound engineering" - all they are is impediments to airflow, and slow down exhaust gas velocity, which is why you don't see much in the way of HP gains form them, and actually lose torque, especially in the lower rpm ranges. When it comes to torque, exhaust gas *velocity* is absolutely key.
No, we will not need to change what we do in the tuning if you change to a different cat-back exhaust system or just do a muffler change like that - that will be fine.
Sound is an intensely personal and subjective thing - you'll really need to hear these in person - YouBoobToob sucks
MGD
