Longtube Headers Installed...snap, crackle, pop
Ever since i had my obx longtbubes installed, along with my x pipe, dynomax bullets and 4x18" tips the exhaust has snapped, crackled, and popped and it's only under part throttle.
If i cruise through the gears, i get the SCP (snap, crackle, pop) especially around 1800-2000 rpm and quite frankly it's annoying
I know the exhausts drone around 1800 rpm but mines less of a drone and more of a sound of crap
Another note: the truck seems to starve and want more power when i shift around 2000rpm and giving it more throttle she wants to move, but less than that it's a bit of a dog, unless im shifting around 1500 it's smooth, deep, and no hesitation.
I've got the gryphon on a canned 87 tune, would getting the custom tune help with the starving of power or is there another issue, leak?
Installed the headers about 7,000 miles back and it's done this ever since i had the true duals fabbed up
Would swapping the bullets out for say a borla xs help emit the SCP or should i be looking at something else here
It's great under wide open throttle but part throttle doesn't seem to be tickling her sweet spot
thanks for any help in advance!
Well I knew this before hand with custom tunes, but will the tunes eliminate the lack of torque or say the need for more throttle to comfortably cruise through the gears?
The tunes take months to arrive and I have fans and possible pulleys going into the truck these next couple weeks.
Will I damage anything running the canned tune, she runs great now besides the above mentioned problem but I want to be certain that I'm not missing anything here
what you are experiencing is common with long tubes and an X-pipe with straight thru mufflers
without a custom tune, your truck risks running lean which if it is, is contributing to the popping...
plus you wont fully benefit from lt's with a canned tune. only a custom tune will take advantage of the flow and will actually equally add power throughout the power range. been there, done that. loved it.
