best price on LT headers
Thanks for the feedback on the OBX. I plan on having the high flow cats. Living in MA. big brother is always watching, and listening. So I will definitely need a new muffler. I guess this is one instance where 10 inches isn't enough. lol. I like the Borla sound and quality. Now I need to find the right one. It will be a quick fix. When budget allows I will probably upgrade again to some kind of x pipe true dual configuration. More homework.
I've got the Roush offroad cat back . It's 3'' from the cats to the sido muffler. I think the outs are 2.5 " . The muffler is small. like 10 inches. I've been told they are made by Borla. I know what Im trying to do has been done many times. Nothing new here. I'm just looking for the best deal on the Best parts. Id like to install them right after I get my 2011 inspection sticker just in case its too loud, Ill have some time to enjoy it. Ooops , I mean fix it. ======== ======
The Dynatech system I was looking at had two highfows and a Y pipe and would bolt up to my Roush system, gaskets included. I have been told that the intermediate pipe that is supplied is crimped though. I was told to purchase some 3 inch tubing to create a less restrictive exit. So with a few feet of 304 and a new longer SIDO Borla, and the Dynatech system, and a tune . I should be able to grab a few more N/A ponies , and broaden my tourque curve.
Not unless your running a Blower or a stock system w/factory cats. That's when you run a 3" for the cat back. You need velocity and flow, they work together and you need the correct diameter pipes , to make it work for you. The wrong set up will cause gases to die in the pipes.
So, stick with 2.5 for the single when running LT's and HF's.
That's the easiest way to explain it.
