Will OBX LT's + ROR = deafness?
#198
Like I said, if nothing else, washers work. Mine leaked from the rear bungs. Header bungs never leaked. So, it was either try to fab up washers or replace the bungs. Decided to attempt the washer deal first. Found some stainless washers that were close, drilled the centers out perfect with a drill press before installing them, - no leaks since. Easier and cheaper since the only other way I would have done it is with a new Y section. If the washers didn't work, that was the plan anyway lol.
#199
#202
Yea, that's one product that's never worked anyway. Not sure what it's good for. Ford and Ingersol Rand uses the best stuff IMO. Not sure exactly what that's called, it's a secret or no one knows lol. I haven't been able to purchase any. The only way to get it is to buy bolts with it pre-applied. Ford uses a blue type, IR uses the orange. Bolts don't come loose from vibration and the stuff seals as well. It looks like a silicone product.
#203
#204
#205
on
http://www.wttool.com/index/page/pro...+Thread+Locker
#206
Use this stuff on my Harley-Davidson....seems to work alright....my brother uses this at the guards jet shop also....only problem is it has to dry on the threads before fastening...
Anyways, I ended up heading to the dealership and purchasing new bolts. The new bolts had the Blue already applied; it was on there thick and looked more like a heavy silicon or something. I asked three people at the dealership out in the shop and no one could tell me where to get some or what it was called exactly lol.
Had I lost other anchor plate bolt instead. That would of tore the brake system up at that wheel as soon as I hit the skidders. That would have been no fun, so ... Yea, knowing that I wanted the right stuff, tried to figure it out, still a mystery lol.
Usually you can find that info on the spec charts from service. Not that for some reason. It's not listed.
#209
Not in my truck! They already stick!
Just washed/cleaned the floor in the garage. We've been in the house just about a year and I don't think the garage floor was ever washed after they built it 6 years ago so there is concrete dust everywhere, er, was.
Hope you like Dos Equis, Pat. That's what's in the fridge.
