Will OBX LT's + ROR = deafness?
Old 06-05-2011, 08:01 AM
Originally Posted by southern2003fx4
I shoulda just got headers instead of replacing my cracked manifold anything is better than 1700 dollars!!!!
Dang dude.......that's about what a plug job on the 04-08 nbs used to cost before the lisle tool....
  #227
Old 06-05-2011, 08:02 AM
Originally Posted by Stealth
I'm going to get started around 8am this morning. Patrick will be by later on.
Have fun!......
  #228
Old 06-05-2011, 09:12 AM
Already going... laptop i the garage too.
  #229
Old 06-05-2011, 09:41 AM
jbrew's Avatar
Live video feed ? I'll break out the jerky for that!
  #230
Old 06-05-2011, 09:49 AM
Hold on, let me get on my Speedo.
  #231
Old 06-05-2011, 09:51 AM
Hey Brew, you think a small bead of the permatex ultra copper around the o2 sensor seal (not the threads) will be OK if it leaks again?
  #232
Old 06-05-2011, 10:52 AM
Everything off now but the passenger header...
Going to clean the driver's side header mating surface now.
  #233
Old 06-05-2011, 11:18 AM
OK that's done. Now going to attempt to put the driver's side back on...
  #234
Old 06-05-2011, 11:36 AM
Driver's side header on, just need to torque...
Water break...
Going to have to go to Home Depot and get some better collector bolts, the cheap *** OBX nuts are already showing stress cracks...
  #235
Old 06-05-2011, 11:43 AM
jbrew's Avatar
Yea, top of the bung. Can't hurt, but it won't last unless you clean the area w/lacquer thinner or paint prep first. contaminant free uknow. It may be better to rub it in, if your unable to manipulate the bead, plus it will cure quicker.
  #236
Old 06-05-2011, 11:46 AM
jbrew's Avatar
So why were the headers leaking at the heads ? You guys figure that out ?
  #237
Old 06-05-2011, 12:04 PM
I can only assume the Ford gaskets weren't sealing because of the port shape, leaking at the seal area. Looking at the soot from the exhaust flowing through there is a semi circle at the bottom of the gasket. You can kind of see it in the picture below.
  #238
Old 06-05-2011, 02:24 PM
jbrew's Avatar
Yea, right there ? That rust probably didn't help much. Hard to tell from here lol.
  #239
Old 06-05-2011, 03:56 PM
Yeah that's the spot.
We're almost done, one bolt on the passenger side is being a pain in the **** though...
  #240
Old 06-05-2011, 07:43 PM
jbrew's Avatar
I'd wizz on a spark plug if it would do yuh any good.
So your done right ?
Quick Reply: Will OBX LT's + ROR = deafness?
