Exhaust making a weird noise
So this morning i went out to make the "before" part of a "before and after" video for my exhaust and it started making a noise ive never heard it make before.(the crackling noise) do you think something is wrong? it was even loud from inside the cab. everything is stock. like i said, ive never heard it make this noise before and ive rev'd the engine a few times before
watch video below...
it only makes that noise when im in park and reving tho. when im in drive, there is no noise.
no ck engine light, no missing, skipping...still rides smooth as ever.
Well my truck does that too....But not that loud..
I have the stock exhaust on right now, and it will let out a pop if you rev it, but its not like that...
I wouldn't be able to hear it in the cab.
Check the intake tube to be sure the filter box is closed right and check all the clamps and hoses near the throttle body... To be sure...
Because that does seem a bit loud..
I could be wrong.
I could be wrong.
I could be wrong.
I could be wrong.
Look for cracks and hard spots in your rubber hoses that connects your PCV valve and other vacum lines..
Just have a feel around....Check everything that connects to the throttle body...
Check the intake tube...Cracks and leaky connection can cause a bad A/F ratio...
We may be jumping the gun, and everything is ok....
Just sounds a bit loud..
Why is the tail pipe all bent.... It looks a lil' goofy i that vid...
Are you sure its a stock exhaust and not something that was fab'd to sell the truck?
and i havent noticed anthing since that video i took this morning.
my new setup is a magnapack muffler, ypipe, and 2 4x18 tips. they should get here thursday. fortunately ill be taking it to a shop to get the new exhaust installed, im sure he will fix anything else that he thinks will cause problems.
