Bad high flow cat
Just got off the phone with Magnaflow (45min conversation)
Turns out the 94106 Cat is made for OBD-I and NOT for our 05+ trucks that are OBD-II....
This wrong cat help accelerate the process of it going bad along with my miss in two Cylinders.
The hi-flow cat MAGNAFLOW Tech rep recommended is this one: 9906HM or the 99036HM for one with an o2 port.
if you need to spend the extra bucks on a better high material cat the 47106 cat is made for OBDII systems.
could this be my problem?????? i have a bad rattling in my passenger side cat and weve been trying to pinpoing the issue for a while and itll rattle occasionally when i go in reverse and take off but it mainly rattles at high rpms and idle. my drivers side cat is installed different than the passenger side the drivers side is installed with the sides of the cat facing towards the ground and sky. the passenger is mounted with the sides of the cat facing to the sides.....
