Drone Issue...
Drone Issue...
I had an exhaust installed by a local shop and I asked them for an 18" oval body Magnaflow SI/DO. They did a great job with the exhaust but they installed a 14" oval body Magnaflow. It sounds mean and I don’t mind the deep rumble but it drones real bad at 2,000 rpms which is right at 70-75mph in my truck. So my question is, will having them put the 18" body cut down on the drone? I assume they will do this free of charge since it is what I asked for to begin with. I will try to post some pics of the tip exits to see if that has anything to do with the drone. It's very similar to KR-TEXAS exhaust, except not true duals. Thanks for the help.
I just put a pic in my gallery. I wanted it to be hidden a little more than it is but it's growing on me. It's not pointing straight down and it clears the bumper by a couple inches, so I don’t think the drone is coming from the exits. Also I made sure they welded the muffler as far back as possible. Thanks for the quick reply ~$t3v3-o~.
(Car Chemistry 2 disc insert) That seems like a good idea. I read a lot of reviews and it seems like it works. How restrictive are these? I know it's still would be better than stock, but I'd like to keep as much flow as possible. If I could keep the rumble and get rid of that 2,000 RPM drone it would be perfect. Thanks
You guys have it all wrong. I just put this new DEI system into my cousins '86 Camaro the other day. We easily picked up like 500hp. It goes so fast now his mullet whips out of his t-tops. Here is a schematic that we used for the welding shop:
It should only cost a couple hundred but it's worth it.
So this "DEI" you speak of. What kind of gains can I expect? And will it void my warranty? Seems like a pretty smart idea and I’m sure the EPA would love it, no emissions! How did you find out about it? Did they give you free headlight bulbs when you bought it....?
I talked to the guys at the shop and they’re going to weld the 18" Magnaflow on Saturday. I’m also going to ask them about the DEI.
maybe if you call them you can special order one for fuel injection
