Drone in the cab
on
I contacted Borla and they recommended the P/N - 400436 over the P/N - 40665 for little to no drone. The 400436 is the muffler used in the 140136 kit. I performed a web search on "2011 F150 5.0 Resonator Delete" and found a YouTube clip of a resonator delete. The delete sounds throatier than the oem muffler, somewhere between a Gibson and Magnaflow system. I contacted the performance exhaust shop that handles all my exhaust work. They qouted $45.00 to remove the resonator and install aluminized pipe, they qouted $85.00 for SS pipe. I plan on stopping by this weekend to have them look at it. I think that is the best option for me. I do not want the exhaust drone at 2000 RPM's on the highway.
http://www.borla.com/products/search...keyword=140136
http://www.borla.com/products/search...keyword=400436
http://www.summitracing.com/parts/BOR-400436/
Exhaust Drone
Exhaust drone & exhaust noise while both are different by definition, both are created as a result of impactors/promoters. Exhaust drone is that which is caused by harmonics- a sound wave generated which in essence takes the exhaust sound and sends it back up the exhaust system (towards the engine) and is released or transferred into the passenger compartment. This transfer typically happens where large contact areas exist that have little to no sound dampening qualities and/or materials- as a result of the muffler construction or vehicle manufacturer.
Exhaust Noise (in passenger compartment) is what most people actually complain about. While harmonics do play a contributive role, it is not the primary cause.
Impactors/Promoters
I would love to tell everyone that “x” is the cause 99% of the time for exhaust noise complaints, but it is typically a series or combination of numerous factors which leads or develops the level of noise which is uncomfortable to the ear. The first “rule” of an exhaust system is that the noise should be generated at the point of discharge (i.e. tailpipe tip). Obviously, if the tip terminates at your door or immediately under the passenger compartment, the sound level will be much greater at the exhaust discharge point than if the tip exits the rear of the vehicle, but this is common sense.
Assuming that there are no exhaust system leaks and isolators are correctly installed at all mounting points, what is not acceptable by industry standards, is when an exhaust system has been installed correctly, exiting well past the passenger compartment to have substantial exhaust sound transfer into the passenger compartment at a level which does not allow a person to talk without raising their voice to well above ambient noise levels. Whether you love to hear your engine roar (which I do), stereo blast or have a conversation, this interferes with your ability to enjoy what you like.
Now for the Causes
The first problem is most muffler shop staff today have little to no knowledge of exhaust systems, the “tricks” to installing a system that will “please” the customer, and simply verbally repeat the marketing materials provided to them by the system manufacturer. As previously noted by several others, there are 3 basic muffler designs, Absorption, Diffusion, and Chamber (Resonator), no matter which one suits your ear best, the criteria for promoting unnecessary in-cabin noise is the same.
Impactors:
Exhaust system material thickness should be no less than 16 gauge- double-walled pipe was commonly available through the 1970’s until manufacturers began seeking ways to reduce costs. Many of the “Muffler Chains” who marketed lifetime warranties always used double-walled pipe before “stainless steel” became the “in-crowd”. If a shop had it available, I would choose double-walled aluminized coated steel or 14 gauge stainless steel (depending on environmental conditions or personal tastes) - it is very quiet, solid and in terms of costs, pipe is pretty cheap, depending on length, 16 gauge aluminum coated runs about $11 to $20 wholesale (depending on diameter), stainless about double for the same gauge.
The muffler should be located as close to the axle (far away from the passenger compartment) as possible, allowing at least 3” of straight run pipe before a bend occurring (if installed to the forward position of the axle), with the overall length as long as possible. In the oem location, 24" will fit fine, located at the head pipe, 30" will fit fine as well and eliminate almost any possibility of drone in this particular location due to the size, length and insulation qualities (and yes, Allied does make units this long).
With regards to the 5.4/4.6 engines, The head-pipe (the pipe installed in between the exhaust manifold and the muffler) should be no greater in inside diameter the 2 7/8”, at 3” it now becomes a contributor.
Duel Tailpipes should be limited to no greater than 2.25” inside diameter, single tailpipes 3” maximum inside diameter- tips which are larger can certainly be installed but should be limited to 12” in length and have a discharge point past any material that may “catch” a sound wave or exhaust. When you exceed these diameters, it now becomes a contributor.
Tailpipe length in general should be as short as possible, minimal bends, etc, terminating past the axle, 1.5" past the body or bumper. Lengths greater than 4 feet promote “drone” (i.e. harmonics), typically about 3 ½ feet past the muffler.
Pipe diameter reduction should occur before the muffler. While many muffler installers like to use mufflers which reduce pipe diameter or split the exhaust at the point of discharge at the muffler, or install reducers to connect the tailpipes after the muffler induces “noise”.
Ultimately, it is the quality of the material and the installer which 90% of the time leads to a successful installation. I would like to also emphasize that it is not necessary to spend a fortune on a muffler ($100+) or system to have an excellent sounding, performing and long lasting result.
Of the major mfgs:
Allied
Edelbrock
Borla
Magnaflow
Hooker
Each uses a "glass-pack" design- All of which use packing material which although is not fiberglass (as no one has used in 20 years), they each use a sound material absorbing design. Even conventional "glass packs" are proven in flow testing to out perform many of the so-called "Free Flowing Real Mufflers". For reference, WyoTech, Hot Rod Magazine has numerous published articals on this. On the net, please read:
broaderperformance.com/muffler_flow_tests.htm (Independently tested cfm flows of the more popular mufflers, glasspacks and resonators @ 15” wc:
2 ½” diameter straight pipe 521
2 ¼” diameter straight pipe 365
2” diameter straight pipe 283
2 ¼” diameter tailpipe 268
2 ¼” round glasspack- no louvers 274
2 ¼” round glasspack- with inward punched louvers 133
2 ¼” round glasspack- inward punched louvers/installed backwards 141
2 ½” inlet/outlet Dynomax SuperTurbo 268
2 1/4” inlet/outlet Thrush CVX 260
2 ½” inlet/outlet Flowmaster 2-chamber 249
2 ¼” inlet/2 ½”outlet Cherry Bomb turbo 249
2 ¼” inlet/outlet Flowmaster 3-chamber 229
2 ¼” inlet/2 ½”outlet Maremount Super C (OEM Replacement) 149
2 ¼” inlet/2” dual outlet Maremount 183
2 ¼” inlet/outlet California Turbo 229
2 ½” inlet/outlet Hooker Aerochamber 324
2 ½” inlet/outlet Hooker MaxFlow 521
2 ¼” inlet/outlet Maremount Cherrybomb Vortex 298
2 ½” inlet center/outlet offset Borla Turbo 373
Allied builds a resonator that is a fraction of the price of Borla( $30-$40), flows as well, is available locally (at just about every muffler shop), and has been around for 40+ years!
Impactors/Promoters
Now for the Causes
Impactors:
Of the major mfgs:
Allied
Edelbrock
Borla
Magnaflow
Hooker
They do have quite a few kit options though.
