Exhaust Manifold Parts
Hey everyone,
I have the oh so common right exhaust manifold leak on my 04 FX4 5.4 due to a warped manifold and i am looking for the parts to replace it. I know i will need the following:
- RH Manifold
- Manifold Gaskets
- Manifold Bolt Kit
Is there anything else i will need? Can someone possibly provide parts numbers for these items and recommend a good place to get the parts. I will not be doing it myself as ive heard its a pain and that you have to lift the engine and the bolts break. I will be having my mechanic do it.
- RH Manifold
- Manifold Gaskets
- Manifold Bolt Kit
http://www.partswebsite.com/fordpart...n=7&type=parts
That is the manifold from the Ford parts website. The gasket was like 10 bucks but I couldnt find the studs...
Or just go to rockauto.com and get the hardware and manifold.
http://www.rockauto.com/catalog/rafr...parttype=15114
http://www.rockauto.com/catalog/rafr...&parttype=5860
I had my right side done at the dealer last year and it ended up costing around $800. Then two weeks ago the left side started leaking so I decided to tackle ot myself. It is not that bad of a job except for the front bottom bolt, it was a night mare. I also broke the top back bolt off, thank god it broke with enough stud left to weld a nut on it and it came out. All in all I'd do a hundred spark plug jobs to a manifold job.
