removed stock air cleaner box snorkel
When removing the 2010 5.4 air cleaner box snorkel it brought the 5.4 to life, through out the rpm range.
Did the same thing to the 2011 5.0 and seems like lost some low end power but above 3k rpm it seems to help. Has anyone done a dyno check on 5.0 with the snorkel removed?
Did you remove any of the resonators?
If you removed any/all the Helmholtz resonators (the small blow molded dead end bottles that are in the fresh air side of the snorkel) you can expect to loose a small amount of low end torque at certain RPM's (frequencies). The Helmholtz resonators are tuned not only to reduce noise, but balance out some unwanted pulses in the induction system that slow the flow of air at slower speed.
