High Flow Recommendation?
I have a set of Dynatech long tube headers and need to replace the high flow cat that came with them. Started throwing errors after 4 or 5 months and the shop believes it's the cause. Running a 2" exhaust into a SI/DO Super 44 muffler. I see alot about the magnaflow 94106 but looking for some opinions......2004 5.4 BTW
That's the cat.
94136 with the O2 bung, 94106 without ...
MGD
Leak upstream perhaps?
https://www.f150online.com/forums/ex...ml#post4709125
https://www.f150online.com/forums/v8...ode-p0420.html
I don't see both cats failing, unless you did something like running a lot of Seafoam, or cheap octane booster, or are running rich enough to toast the cats, etc.
MGD
MGD
I've never added any additives but can't say on the running rich part. I'm not sure what would cause that or how I would even check it? I should add that I was only getting an error on the passenger side bank for the longest time. It would trash my O2 sensor after a few hundred miles. I had the shop move my O2 bung back a little farther on that side and quit having that problem, but began getting these new errors in it's place.
