2 New Cat Questions
2 New Cat Questions
OK, couldn't find any answers on these two...
-I have a CA built truck, but the truck is no longer located or registered in CA Plan is for the infamous 94106 universal hi flow cats. However, Magnaflow website says not for CA OBDII equipped vehicles. Inspection/emissions aside, will there be any problems mechanically running these cats on my CA truck?
-We've covered welding a bung in the pipe right behind the cat for the downstream O2 sensor. However, Maggie has cat # 94136 that has one bung already installed and 94166 that has two bungs already installed. What's wrong with one of these options? Is it the wrong thread or somethign for our O2 sensors? Why are these not the more popular option?
Purty much take yer pick. No OBDII issues.
I'd use the bung-equipped cats - one less invasion into yer tubing that way.
Threads are ALL standard.
*EDIT* - from Innovate's LM-1 manual - fyi on bung/sensor installation:
Install the oxygen sensor’s bung upstream from the catalytic converter
(a bung and plug is included in the LM-1 kit). Any decent muffler or
exhaust shop can do this for you. The wide-band oxygen sensor is then
installed into the bung to take a reading. (Insert the plug into the bung
when not in use). The bung must be installed in the exhaust pipe at
the side or on top, NOT on the bottom of the exhaust pipe. Best
position is between 10:00 and 2:00 position.
MGD
Yep - all 4.
And use Motorcraft ( Rockauto).
Here's why: http://www.vmptuning.com/forum/showthread.php?t=825
