Loss of gas milage due to increased flow?? Does it happen??
Hello everyone. I am currently looking at the purchase of a new exhaust system. I have it narrowed down between the Ravin or Vortex. The concern I have is, if I increase the airflow substantialy by increasing pipe diameter and putting on a high flow muffler will my gas milage go down. The reason I ask is because when I owned my Dodge Dakota, I cut the muffler right off and straight piped it. It sounded pretty cool, but because the O2 censor was directly infront of where the muffler used to be and there was no backpressure thus the computer thought the engine was cold and therfore the engine ran rich, even thought I had been on the highway for an hour or two. Has anyone had this happen? I know when I talk muffler guys they all claim gas milage should increase slightly, but I don't want to find out the opposite after I have spent the money on the muffler etc...
I also have another question. Should I go 3" or 2.5" on the tailpipes on a single in dual out set up? Help guys I am getting close to decision time
Cheers
O
Cheers
O
Increasing exhaust flow is not going to decrease MPG, if you do it right. If you replace the stock muffler with a good aftermarket muffler, you will increase the flow. I used a Flowmaster 50 series and got about a 1 MPG improvement (and a noticable gain in HP, but I have no way of measuring it). I left it as a single 2.5" system.
If you replace the stock muffler and go to dual 3" pipes, you will hurt low-RPM performance. But not because the system is too free-flowing. A bigger pipe reduces the speed of the exhaust gases. Keeping the speed up helps suck out the exhaust gases.
The whole exhaust system is a compromise. A large diameter system will give you great WOT performance, but won't be good for low-RPM use. A small diameter is great for low end torque and MPG, but at high RPM it will be too restrictive and the engine will waste power having to force the exhaust through the tiny pipes.
I think the proper size pipe is 2.5" for the 4.2L and 4.6L, and 3" for the 5.4L. That's for a single exhaust, I forget the numbers for dual.
I recently had a SI/DO setup installed on my '97 4.2L F-150. The service manager advised 2 1/4" pipes and 4" tips. I gained a lot of low-end and didn't loose anything at WOT. The 4" tips make it sound very nice . My V6 doesn't sounds raspy at all. Sounds just as deep as my neighbors 5.0 F-150 with a stock exhaust.
I can't verify that the gas milage has increased yet but my engine seems to breath easier and transfer power to the rear wheels with less effort. The idea is that by opening up the exhaust you will make it easier for the engine to push out the burned up fuel thereby making it work less and increasing your MPG.
Looks very classy too.
