Technical Questions
Technical Questions
Hey guys!
What is the difference betweeen two mufflers, a DI/DO mufflers or a SI/DO muffler setup, sound and performance wise? What defines true duals? Is putting a flowmaster Y-pipe after the stock Y-Pipe essentially the same thing as an X-Pipe? Thanks for any input guys! P.S. sorry about the depth of the questions...
-Mark
-Mark
CarMan-
True duals are 2) completely separate pipes that run from each bank/exhaust manifold of your engine. This setup can be configured with 2) SI/SO mufflers or 1)DI/DO muffler; an X pipe can also be included between each pipe. Sound is quieter with 2) similar mufflers over one and performance will be based on flow. The FM Y- Pipe is a modification that replaces the factory Y- intersection on a single pipe setup.
Max Mitchell,
Thanks for replying man I'd asked this question a few imes already in other forums and noone seemed to know.... Anyways, that's weird that one muffler is the loudest. I always thought trucks with true duals sounded louder than my friends FM 40 SI/SO but whatever. Thanks again man! -Mark
