Y-X-pipe hybrid? / Y-pipe mod?
First: I did a search, but I can't exactly find what the "y-pipe mod" is. Does is it the fabrication of a centered Y (in place of the offset Y)? or ______?
Second: Just a theoretical question for you all. Has anyone considered the fabrication of an X pipe which crossed back into a Y-pipe that goes to a single in & out muffler?
I figure than a Y pipe is similar to an H-pipe, so why not X it if possible?
The attached picture is pretty bad, but it gets my point across.
Are you sure the fluid dynamic (and acoustical dynamic) properties of a Y-pipe and X-pipe are the same? (especially considering the unequal lenghths of the Y-pipe with respect to the 2 to 1 intersection)
So the Y pipe mod is essentially adding a mandrel bend to replace the crap bend of the stock?
Here's the infamous jagged hole inside the factory Y-pipe. Some are far worse than others.
This is how it shapes up after the mod . I'm sure you can understand how the factory Y-pipe restricts the driver's side of the "Y" from flowing freely into the passenger's side.
Photos are " ala Jackal " I found them by using the search function.
Good luck Corpsie.
Good luck Corpsie.
