F150 Magnaflow Cat-Back
I installed a cat-back system with a magna flow (medium noise) muffler.
The shop used generic mandrell bent pipe over the axel with a custom bend which exits behind the rear wheel. They fabricated the other 3" pipes and hangers to complete the system and installed a nice crome tip.
Everything is welded, no clamps. The magnaflow has a deep throaty sound and doesn't kick-in until you put your foot in it. Cruising on the highway you don't hear it from inside the cab. Sounds excellent with the FIPK.
I recommend the magnaflow (medium) for the f150.
They only charged me $225.00 installed. It's aluminized, not stainless, but who needs stainless in Californaia?
Boardcat,
A few question's if you don't mind. I went on magna's website & could'nt find just muffler's. Did you order the cat-back system ?
Do they have diff. sounding muffler's ? You said your's was medium,do they have low or a high loudness ?
Do you have the SI/SO system ? Did you lose low end torque ?
Thank's...Mike
Thank's...Mike
Originally posted by FALLSCREW
Boardcat,
Thank's...Mike
Boardcat,
Thank's...Mike
http://www.magnaflow.com/03cat-back/...aluminized.htm
A rule of thumb is, the longer the muffler, the quieter the sound.
