straight pipes
if you have "true dual" exhaust, you essentially have 2 separate 4 bangers exhaust systems. You NEED and H-pipe or preferably and X-pipe so that the scavenging effect will occur between the 2 exhaust banks.
X-pipe info
X-pipe info
Then why not just add a crossover tube?? Hp isnt the only thing to look at for a 4x4. Especially if you are going to be towing or offroading. low end torque is actually a little more important. Also the way new cars and trucks are, all the parts are tuned (picked) to harmonize and work together. Therefore if you change something on one side, you should change something on the other. For instance, exhaust- intake. Just what I've learned. I hear the best bet is just changing the muffler to a high flow unit or using a Gibson or similar cat back.
