clearance ?
Shouldn't be a problem even on the "4 arm" type lifts (usually used for cars) as each arm's pad is adjustable vertically for height and the frame is pretty much same height as the bottom of the box panels. But usually they run pickups onto 4 post ramp lifts.
Don't think you'll have any troubles. Otherwise the f150 L guys would be screaming too.... ground effects for worse clearance.
