dual vs single
Most people will agree the best solution is to replace the factory y-pipe with a flomaster piece, replace the garbage-can OE muffler with a 3" SI/SO performance muffler and a single 2.5 or 3inch tailpipe.... like a Gibson sweptside type system... not that I condone any single manufacturer... Gibson mufflers (non-stainless) seem cheap.
Unless you're running 350-500+ HP this is the most economical and powerful combo.
While some duals may sound nicer (subjective) you have extra pipe = more weight, more expensive for nothing.
In case you missed it we've discussed it to death here: https://www.f150online.com/forums/sh...threadid=73370
My 2 cents.
My 2 cents.
My '97 4.2L responded very well to cat back duals. I noticed right away that my truck felt lighter accelerating from a dead stop and passing on the highway.
Back pressure is a big consideration. Reduced back pressure is good for high RPM horse power but very bad for low RPM torque.
A high flow muffler with a single 3" exhaust pipe should give a small increase in noticable power and sound good as well without much of an expense.
I have duals because I liked the look of 2 shiny, slash-cut tips comming out the back. It's a Dynomax Turbo muffler. The pipes are 2.25" and the tips are 3.5". Sounds very good as well.
Duels for sure
I personally had my Y pipe split by the o2 sensor and had two going inot the muffler and two going out. The only one that I could find to do this was a brand called Mean Streak. I have heard that Flowmaster now has this too. I highly recomend two going in and two going out of the muffler instead of a single in and duel out. MORE POWER!!!!!
