True dual (like Lightning) exhaust on the S'crew?
I'd like to put a true dual exhaust on the S'crew, like what's on the Lightnings. I was thinking I could order the Bassani cat pipe that goes on right after the headers, and the Bassani cat-back exhaust, and then just extend the pipes between the cat pipe and the mufflers so the tips exit in front of the rear wheels (since the S'crew is longer than the Lightning and we can't have the pipes coming out under the back doors). Has anyone done this? I was poking around under the truck and there seems do be plenty of room, as long as the S'crew and the Lightning use the same transmission support cross brace since the pipes have to clear over the top of it. Any info (or picts of your Lightning's underbelly) would be greatly appreciated.
Check out this post. There are some really good siggestions here as well as some pictures of Lightning duel exhausts.
http://198.65.157.241/forums/showthr...4&pagenumber=1
Good Luck!!
Good Luck!!
