Rear window leaks
I've had that problem several times and they keep tightening the bolts and now they have replaeced the rear seal.. Hopefully that will work, also i've had seat squeaking noise and they replaced the lumabr but the squeak is still there I have 34k on it and is only a year old, also as an fyi i just got my throttle body and injectors cleaned and gained about 1.5 mile to the gallon.. it's a big deal when you get 12.5 to the gallon and as far as transmission they replaced my tr sensor (transmission range) has something to do with shifting.
Good Luck
Good Luck
