Rumble noise coming from the rear?
I am having a terrible problem pinpointing the noise that comes from the rear of my vehicle while driving. If you can follow this: When the Expedition is at about 2000 rpm's, the vehicle will shift gears at about 40 mph. I will hear a deep rumble for about a second(like you would hear when you veer onto the shoulder of the highway onto the rumble strips (aka "wakeup strips")) and then an even more pronounced rumble when the vehicle again shifts into the next gear at 55 mph. It happens EVERY time - As long as I stay at around 2,000 rpm's. If I "punch" it, it acts normal (no noise), or if I keep the rpms above 2500, I won't hear the noise. I'm lost, any help would be greatly appreciated!
PS. Its not a grinding noise, it is more of a rumble and the entire vehicle vibrates like some serious bass in the speakers!
99 Bauer, that is your tranny going bad. I had the same problem last year and my local dealer had to rebuild the tranny and install a new torque converter. One of the salesmen told me it happened on his 2K also. Luckily I have an extended warranty that covered all the work. It should be a recall item.
