Rear window won't latch/lock....
Might seem silly but make sure the latch is open first.... Use the handle and if you hear it pop when you turn it, then there's your answer.... The other way is to use some grease.... See if a friend has a grease gun... Apply a LITTLE into the latch... WD40 is fine, but will last only so long
