Drip/leak from rear of '03 Expy...
Does anybody know what might be dripping/leaking from the rear of an '03 Expy? I have a small drip that is running down the front of the rear differential. It seemed like mostly water with a little dark color to it and it is staining the driveway. Could it be the rear axle shafts?
Thanks for your help.
No leak. Just had the entire rear replaced with the right side shaft.
For some reason the limited slip clutch pack went bad and the shaft that connected to the gears was apparently damaged so badly they could not disconnect it from the assembly.
Runs good now. No vibrations. No leaks.
Ford!...
If I could only get the doors to stop rattling.
BTW: I live in Northern VA near Dulles. You?
Ford!...
