98 Expy headlights
98 Expy headlights
Hello All,
I am having a problem with my headlights. I had the superwhites, forgot what brand, for a while now. My right side light keeps going dim. I will replace it and it will work for a week or so and them just go dim. When I put the stock headlights back in, they did not go on and the bright light indicator on the dash was stuck on. I tried to flash the lights and nothing would happen. Running lights worked fine. Then, all of the sudden it went off and the left light works, but the right is dim. Any ideas.
Silverstars are safe... there are oodles of folks running them in heads and in fogs (many in both heads and fogs)... You'll be fine with them.
I have them in my fogs and have had ZERO problems over the past 8-10 months that I've had them. As for the heads, I replaced my set with a HID (High Intensity Discharge) system from Sylvania... Xenarcs.
RP
RP
