99 5.4 hp# and 4x4 tow rating?
Rear axle makes a difference too. I think it wasn't until 2000 that tow rating got as high as 7800 on a 2WD with 17" and 3:55. Seems like 7300 may be it. Check the Towing forum. There was a "post-it" post that had a link to a tow rating chart.
Also, toe rating can be over "rated". Be sure to watch gross weight ratings. I can be 300 lbs under my "tow rating" yet be over on gross weight pretty easily.
Don't you love Fords owner's manual for the 99.
Doesn't give a rating for the 5.4 with a 3.55. If you just looked at the owner's manual you wouldn't even know ther was a 3.55!
The 3.73 w/ 5.4 4X4 is 7500
The 3.31 w/ 5.4 4X4 is 6400
I'm pretty sure I read (not in the manual) that the 3.55 will allow a 6900 tow.
You also would know there were PI heads that give you 260hp!
