A/C Recycling noise
if you are referring to a sound of the compressor clicking on and off, then you may want to check your freon levels. The less freon in the system, the more times it has to "cycle" to keep the air cool.
If that is the case, make sure you check for leaks. Or else you will be back to square one in only a matter of time. Until then, watch your use of the A/C. You don't want to burn out anything prematurely.
Good luck.
Good luck.
