Clunk noises need addressed on '99
I just bought a 99 Eddie Bauer 4X4 that has the load leveling suspension. Since I bought it, there have been clunk noises coming from the rear when I go over bumps... not sure if that just means the rear shocks are bad. Sounds like something is bottoming out. The next clunk is coming from the front right corner... doesn't matter if I am just driving along or hitting bumps. Could this be a bad CV joint? Truck has 93,000 miles on it.
If I have the front end apart, I am going to do ball joints and CV joints both sides... wheel bearings I would leave alone for a while.
Any ideas?
Any ideas?
clunk
I'm in the same boat... er, clunker. I've got the clunks coming from the front of the expy (definitely isolated it to the front). I replaced the front shocks this week thinking it was the tired/loose OEM shock, but that wasn't it. The sway bar and ends seem to be intact and tight. The ball joints don't seem to be bad (not very much play when checked). I can't find anything wrong with tranny mounts, motor mounts, heat shields, tubing, or anything else that could bounce around. If I didn't already check, it almost sounds like a rock in the wheel cap.
I'm a step away from dissassembling the front suspension, but my wife doesn't want me to do it.
Any more suggestions out there?
