Expedition / Navigator
Towing with my 99 - is this too much?
Old 07-14-2004 | 05:12 PM
93Cobra's Avatar
I am towing the Lightning down to TN from Ohio... 432 miles. I have a 1999 Expedition EB (4X4 w/ towing package) that I am using to tow an enclosed trailer - 4100 lbs. The truck weighs in around 4600 lbs. I know that this exceeds 7500 lbs, but could it be done safely?
Thanks.
Old 07-14-2004 | 07:38 PM
PaulC's Avatar
I'm assuming that you mentioned 7,500 lbs. because your Expy has the 3.73 axle ratio. 8,700 lbs.? My understanding is that Ford recommends a weight distributing hitch (which the factory hitch is not) for loads over 4,000 lbs. Will the Expy be loaded with passengers and/or gear? More weight...
This sounds like a job for an F-350.
Old 07-15-2004 | 08:20 AM
93Cobra's Avatar
It will be just myself in the truck, and a bag with some clothes. The trailer has electric brakes that I could wire in, but I am thinking that this thing will be far too much to tow safely.... do not want to have a chance of hurting the trailer or the Lightning inside
Old 07-17-2004 | 12:41 AM
FamilyRide's Avatar
8700#??? I towed our boat that tops out at about 7500# and I wouldn't do any more than that; and I had mine modified.
I would definetly want WD setup with that. Boats are generally very well balanced and mine was fine even at high speed. A box trailer like that I would not tow without WD equipement. Even with WD, the weight alone would make me scratch my head with a 4x4 Expy........
Quick Reply: Towing with my 99 - is this too much?
