2004 Expedition Help!
Originally posted by LE PEW
What's this money rotting system that you're asking about?
Seriously tho, what does it monitor, tire pressure, wheel revolutions? What is it doing that makes you want to disable it??
Where are the old wheels?
Just unscrew the nut aroud the valve stem and they should come out.
You would have to see if they would fit the new wheel.
Also you are supposed to replace the gasket on the stem when you remove and replace them.
I dont have the part number.
Check here
http://www.parts.com/partlocator/ind...04&catalogid=2
Check here
Found this doing a search.
Did you get "Tire Pressure System Fault" or "Tire Pressure Sensor Fault"?
Just got new tires and rims for the wife's Expy (2004 EB) yesterday. Everything was cool. This morning she got the SYSTEM fault code above. Are you saying it will never go away? Seems like if the sensors were not installed on the new valve stems you would get the SENSOR fault code.
Were you able to fix this?
If you can't get the stems from the old wheels put on the new, the next best is to check with the dealer and get them to disable it via the computer. There is a way or else everybody with aftermarket wheels would be complaining.
You also might want to check over at www.fordtruckworld.com. They have a fairly active expy/navi board. Good luck.
Turns out the Truck Shop didn't transfer the sensors to the new tires and rims (because I didn't tell him to). He is doing it today, free of charge. Evidently only some (just a few) aftermarket rims will accept the sensors and the ones my wife had picked out do (Eagle 101's). Most Welds will too from what I gather. If anyone else is picking out rims for their Expy, make sure the rims have a flat area to mount the sensor. Hopefully all will be cool when we pick it up tonight.
