Installing skid plates 04' Expedition 4X4
I have an 04' EB 4x4 Expeditions that I am trying to install skid plates on. I have purchased the front and rear (gas tank) plates and the required hardware. I have the front plate mounted. The rear skid plates require removal of the gas tank straps and replacing them with new ones that have bolts welded on to mount the gas tank skid plate. I have installed the front gas tank strap and need to do the rear, but have run into a problem. The straps fit into a slot and then turn 90' to wrap around the tank. There is not enough room to do this with the tank in place and the driveshaft in place.
My question is... Do I remove the driveshaft, or drop the entire tank? Will the tank slide side to side enough to install the strap without doing either?
Thanks,
Thanks,
