Need a New Truck/Thinking 97/98 EB Expy
I am considering buying another Expy. I owned a 97 which I ordered and bought new when they first came out. I got the 2nd one they had on the lot. I traded a 94 twin turbo Supra for it. My Expy was a 97 Black 4x4 4.6L. Here is a Pic...
I only kept the truck for two years and it had 36k miles on it when I traded it for a 99 Cobra when they first came out. Here is a pic of that...
The Expy I'm looking at is a 98 Wedgewood Blue EB w/ 68k miles, same wheels my first one had, overhead air, and third row seat. Naturally it has the 5.4 engine.
Question is, since my ownership experience with these vehicles was short and my truck had a different engine, are their any obvious problems/recuring issues that I should be aware of with the 97/98 EB Expeditions?
Thanks Guys!
Steve.
Thanks Guys!
Steve.
I went with the 98. I found why the original owner traded it in. The 4x4 doesn't work. Everything from inside the truck indicates it is working properly, but when you get it in the slippery stuff the front wheels don't pull. I'm stumped. I can't imagine what would keep it from engaging when everything else seems to be working. Any ideas?
Originally posted by rainman15
What is a PI Head???
I know what a head is, but don't know what PI means.
Do you hear the "clunk" when shifting to 4LO (Neutral,truck not moving )? Motor working if makes clunk noise. My 97 4x4 had the front axel ****er rusted (I see you are in Ohio too, rust belt). It is near the front diff under cover,actuated by black vacuum motor. Once freed up, I lube it once a year or so. Kind of a shaft to lever arm thing, rust can stop it from moving. Mine 1st failed under warrenty. This can/will cause no 4x4 action, even when all else works (you do have a 2hi position right? They eliminated this for 99-? years I think. when 2HI was removed) Hope this helps Mark
I think PI started in 99 hence all the head gasket leaks,etc in 99
Just got the call telling me it was the vacuum motor. They are replacing it and I should have it back by lunch tomorrow. The check engine light came on during my trip to the dealership to drop it off and they said that is an O2 sensor that they are also replacing. Glad I had a warranty. In the furture I'll be checking that motor during my fall preventative maint. Thanks for the help guys!
Steve.
PS Ohio weather Sucks!
Steve.
Good guess huh!!! Actually vacuum motor probably OK but they had to sell ya something (oh,warrenty). It just doesnt have the "poop" to break thru the rust. I try to got into 4x4 once a month or so to keep free. Spray with med thick oil stuffonce a year.
I just did my passenger side o2, what a bear , no room. These were know to go cause of A/C dripping on top of them .Dealers were given a "fix" (lenghten tube) , but clearance makes installing it a dream...
Other neat rust related stuff to watch out for ,park brakes,horn,hood latch spring,exhaust stud breaks...
Mark
Mark
Steve.
Steve.
Originally posted by PaulC
Glad to hear that they nailed the problem. Now that the Expy is 100%, you have no reason to keep that Pathfinder.
And I will be keeping an eye on that front end from now on.
Steve.
