Gas Tank Noise
Gas Tank Noise
I've got an intermittent whistling noise coming from the gas tank. Other than the filler cap, is there any vents on the tank that could cause this noise? I've tried changing caps with no luck. Someone said it may be the fuel pump, but when I remove the cap, the whistling goes away. Any other suggestions would be helpful.
Thanks,
John
Thanks,
John
