Aftermarket receiver with Mach system?
#31
Originally posted by rainman15
They are going to refund my money, but the wasted time is worth more than the 20 bucks to me. I did pull my stock deck out to look at the connections. It has a rectangle shaped plug on the top left corner and a long thing plug in the middle. I still have the harness from my 03 Lightning on the deck I intend to use and I pulled the expy deck to verify it wouldn't work prior to trying to order a new harness. As for the heat sink on the sides I don't exactly know what that means.
By heat sinks, I mean like gray metal fins on the sides. Like the fins on a amp.
#32
Originally posted by Buzzz
So they couldnt offer to send you the correct harness?
#33
They did offer to send the correct harness, but it was over $50 so I declined. The installation of the aftermarket deck was just a temporary fix anyway. I'm going to install my entire system this spring once it warms up and finally stops snowing. I just wanted something decent to listen to until then. Obviously that isn't possible with the mach system.
#34
From what they said the 97/98's had amps for the forward speakers (everything but the rear sub) in line between the deck and the speaker, and the 99-02 had the amp for the forward speakers built into the head unit. To run an aftermarket deck on the 97/98 the harness has electronic adapters built in to level the power input to those factory amps. You can't run power to power. Boom!
#35
#36
Got the harness and installed it and hooked up my xm commander to it,,,,, it sounds really great, i didnt expect that from the stock sub, wow!..
Does anyone have any tips for mounting the xm on the centerconsole right where it meets the dash under the hvac controls? I was thinking ole fashion velcro would do the trick?
#37
Yeah, because the signal strength from your sub out is much more than the OEM deck. I have my sub level set to -3.
Makes me want a better/bigger sub though. Its just a teaser
#38
#39
I notice that if I turn it up past about +2, i get a "popping" sound from the sub....I plugged the rca from the harness to the red rca hanging out of the back of the pioneer deck...is this hooked up right? thnx
I get a slight pop too if I crank the sub level past +1. Its overloading the stock amp. Just keep the level lower.
#41
