NAPA PArt # for Front AIR SUSPENSION
I was just given a NAPA part # of "40004" for a replacement front air shock for 4corner air suspension 4x4 Expy. When you put the napa part # 40004 in the napa web site, it comes back with "Specialty Front Shock", and sells for under $80. Can anyone confirm that this is an accurate replacement for our stock shock??
Re: NAPA PArt # for Front AIR SUSPENSION
Tenneco Automotive, the makers of Monroe and Rancho shocks and suspension products, does indeed make these shocks for Ford.
I spoke with a Rancho tech not too long ago and he was able to give me detailed specs on the Ford/Lincoln OEM LLS shocks.
I'm guessing that Monroe's "OEM exclusive" contract w/ Ford ended and they are now allowed to sell them via aftermarket channels.
I have every confidence that these are the very same shocks you would buy from the dealer, save for the "Monroe" stamping.
JAMES.
JAMES.
Thanks for the report.
What is the year and mileage of your vehicle? What was the improvement in ride or handling quality?
What did you do with the air suspension system during the shock exchange? I presume that those air lines were pressurized. Is there a procedure for depressurization prior to replacement?
Thanks!
JAMES.
Thanks!
JAMES.
I finally got the shocks on yesterday. WHAT A DIFFERENCE!! I didn't realize the front shocks were as bad as they were until testing the new ones... Install is a breeze, but found that I had to remove the bottom mount of the ride-height sensor to be able to remove the shock...
my Expy is a 99 4x4 Eddie Bauer Edition, 5.4 liter with the 3.73 rearend. It has about 108K on it now. I replaced the rear assist shocks lat year with Bilsteins. I immediately noticed improved ride. As far as the install goes, all I did was turn off the air suspension system, and disconnected the battery. There's a green "ring" around the air hose. Just press in the ring, and pull out the hose. It's as easy as that. On install you simply plug in air hose.
