From F-150 to SUV (maybe)
I have a '99 F-150 XL with a 6.5' box. I'm sorta kinda considering a Ford SUV for my next vehicle. I'd like one that has the same cargo space (with the back seats folded down, if necessary). Size-wise, which Ford SUV is most comparable to the F-150 I have now?
Thanks!
Tracey
Thanks!
Tracey
Well, I measured my 2000, and it is about 6 1/2' from front to back on the floor with the seats folded down. I would guess that it is a couple of inches shorter when measured across the ceiling, due to the sloping of the rear window.
Entry height is about an inch short of 3', but it gets a couple of inches taller once you get through the rear hatch opening.
Width between the wheel wells is just over 4'. If you get an Expy with rear heat & AC like mine, then the driver's side wheelwell will be a solid tall panel (as opposed to the wheel well "hump").
Hope this helps.
Hope this helps.
