Oil pathway to timing chain tensioner
![wave](https://www.f150online.com/forums/images/smilies/wavey.gif)
My '98 Expy has 200,000 and I was hearing some clattering going on under the front cover on the passenger side. The chain on the passenger side was indeed loose when I first pulled the cover. I replaced all of the timing chains, tensioners, cam gears, etc. I thought it was just a bad tensioner, however after about 2-3 days of driving with the new stuff installed, the noise is back. Someone on the F150 post said it could be the Cam ladder is clogged not letting the oil flow to the tenisioner.
Question 1: Can I remove the CAM ladder without having to lock down the crankshaft with the holding tool?
Qestion 2: If I pull the front cover and the valve cover, then remove the CAM ladder, can I force air from a compressor back from the tensioner location up through the CAM area to try and clean out the pathway.
Many thanks for any help anyone can give me.
on
Originally Posted by jc1998Exp
<snip>
