Broken antenna
I just checked www.fordpartsnetwork.com. You can buy a new base. My 2002 had the antenna break off in side. Remove the anteena base cover. Remove the screws holding it to the fender. When you pull the base out it should have a connector to the wire. Just disconnect it and get a new base. I paid $10 if I remember correct. You can get the base at the dealership, should be in stock..
