Expedition / Navigator
On a 2004, the engine on an expy can be a 2 valve per cyl. 4.6 or 5.4. A navi is a 4 valve per cylinder 5.4. 18" wheels vs. 17". I guess you already know that most things that are optional on expy's are standard on a navigator like all navigators have 4 wheel air suspension, power fold mirrors, memory seats, reverse sensors, etc.
That would make sense wouldn't it, but the three valve '05's require premium in the Navi's. Don't know why they would other than since it's Ford's idea of a premium vehicle I guess they fiqure it needs premium fuel.
One other difference between the 05 navis and expys is that the Navi has a five speed or is it six speed auto instead of the four speed in the Expy.
Originally Posted by kidtriton
I have always run regular unleaded in my 01, and 03 navigators. I only hear a very quick spark knock sometimes if i jab the throttle.
Personally I've never figured out why someone would buy a $50k vehicle and then skimp on fuel.
I challenge you in your '03 to check your fuel mileage after a trip,our your routine run and then fill up with premium and good top tier fuel at that, and then reset your computer by unplugging the battery and turning on the lights. The result is almost always a better Mpg.
For our Navi my wife driving gets about 13.9mpg on Chevron or Texaco supreme. 3/4 in town the rest of course highway. On a trip with me driving I get about 14.5 cruise set at 80 and several blasts into the triple digits in the desert. Speaking of that it would be nearly impossible to hear the knock at a high speed due to road and wind noise. Good luck.
I know how it works, i've been a Ford Master Tech in Engine and Chassis for the past 10 years, just left ford recently. Look up my posts in the engine and electrical sections from the past 5 or 6 years. The way the knock sensor works on these is as follows:
There is a normal section of data in the PCM for controlling timing advance. Then there is another, alternate table that has advanced curve rates (up to 7 degrees extra). If the vehicle even uses data from the knock sensor ( some, including a 99-04 lightning, do not even have the capability of making changes based off the ks) then it will use values from the alternate table as long as the voltage on the return of the ks stays below a certain level. The vehicle will perform just fine using the standard timing tables though. Even if the engine was detonating significantly, the PCM cannot "retard" the timing any past the base table values. And 7 degrees of timing at cruise makes little to no difference in fuel mileage.
I do mostly city driving, average 14.5-15 MPG, i drove it from NC to NJ in april and averaged 17 MPG for that trip. I do have a 2wd though.
Also, i only paid 28 grand for my 03 with 32k miles on it.
FWIW the knock sensors are turned off in the L's because the S/C makes too much noise and the sensors get fooled. But then you knew this already I'm sure.
on
Originally Posted by MHMCGILL
Do a comparison between the the two fuels and then come back and through it in my face.
BTW I never asked how much you paid for it but I am glad you got a good price.
In fact you should buy me a beer, because if it wasn't for people like me there would be no used vehicles for people like you to buy.
These have all been bought by me brand new since 2001.
http://www.buildabox.net/pasttrucks/IMG_1880.JPG
http://www.jlmicro.com/f150/IMG_2099.JPG
http://www.buildabox.net/expedition/IMG_0733.jpg
http://www.buildabox.net/pasttrucks/03supercrew.jpg
http://www.buildabox.net/pasttrucks/02beige_2.jpg
http://www.buildabox.net/pasttrucks/02screw_1.jpg
http://www.buildabox.net/pasttrucks/fx4screw.jpg
http://www.buildabox.net/pasttrucks/01beige_2.jpg
http://www.buildabox.net/pasttrucks/01screw_2.jpg
http://www.buildabox.net/pasttrucks/01white_2.jpg
http://www.buildabox.net/pasttrucks/lightning_2.jpg
and heres a couple of the used vehicles ive had in-between
http://www.buildabox.net/caddy/IMG_1819.JPG
http://www.buildabox.net/navi/IMG_1417.JPG
http://www.jlmicro.com/navigator/IMG_2555.JPG
i was wrong, out of the 47 vehicles ive owned, only 18 of them were brand new.
1982 honda accord - used
1986 tempo - used
1984 mustang 4cyl converted to v8 - used
1990 lx 5.0 hatch grey - used
1994 F150supercab white - used
1994 mustang gt black - used
1988 lx 50 hatch red - used
1990 lx 50 coupe black - used
1994 cobra white - used
1994 f150supercab blue - used
1990 mustang gt white - used
1989 thunderbird supercoupe - used
1996 mustang gt silver - new
1997 f150 reg cab red - new
1989 lx 50 black - used
1987 mustang 4cyl converted to v8 - used
1994 f350 supercab dually - used
1996 mustang gt green - used
1997 f150 supercab white - new
1997 f350 dually crew cab - new
1998 f150 supercab red lariat - new
1998 f150 supercab black lariat - used
1999 gmc z71 white - used
1999 f250 supercab white - used
2000 f350 dually crew cab - new
1997 f150 supercab red lariat - used
2001 f150 supercab white lariat - new
2001 lightning white - new
2001 f150 supercrew green lariat - new
2001 f150 supercab beige lariat - new
2002 f150 supercrew gray lariat - new
2002 f150 supercrew white lariat - new
2000 f150 supercab white lariat - used
2002 f150 supercab beige lariat - new
2003 f150 supercrew beige lariat - new
2000 f150 supercab green lariat - used
2003 f150 supercab white lariat - new
2003 expedition eddie bauer white - new
2001 navigator tan - used
2002 escalade white - used
2002 tahoe tan - used
2001 navigator tan (different one) - used
2004 f150 4x4 supercrew lariat black - new
2001 acura tl - used
2004 f150 4x4 supercrew lariat blue - new
2003 navigator - used
1986 tempo - used
Well you got me, good for you. It's amazing all that money spent on vehicles and you can't spend .25 more a gallon for recommeded fuel. Something just doesn't add up but then again I really couldn't give a .......
I do have to say buddy that I had no idea Ford techs make that kind of dough. Maybe that explains the shop rates. Good luck.
