How to fix rear half shaft to hub noise...
My '03 has had the TSB for locking nut, new half shaft and hub assy, several attempts and so far nothing has lasted longer than a week or so. Once the half shaft starts to slide around inside the splined hub, I get a loud snapping noise
changing directions or even sometime slowing down. I know it's related to these parts and there must be a tolerance stack up issues between them.
Anyone know if they redesigned the parts lately ? Right now dealer is out of
ideas and so seems the zone office.
fyi
Jerry
fyi
Jerry
jeraa2t,
Can you describe the noise in greater detail. I have an 04 and am trying to diagnose a problem that might be similar to yours. When I change directions in low speeds (from R to D to vice-versa) I get a popping noise when just taking off. I also get a thud noise when the truck downshifts and sometimes when slowing down. Are you getting the same things or am I describing a different problem?
Thanks.
Thanks.
Sounds like it
The snap noise which sound like a bad cv joint on a ront wheel drive car or if you drove over a walnut is what I get on the rear end.
And you can get it when u go from D to R etc..
I was able to show it by just leaving it in park and rocking the car by hand/body back and forth hard against the parking pawl. There is a tsb for diff
locking nut etc. That doesnt work either. The Expy is in now for them to lookat it again, but basically new half shafts and new hub assy cured the problem for about a week. It's a design problem as far as I can tell. There is too much slop
on the spline.
I am waiting for it back as this is the last shot before warrenty expires. I also lost a sensor in the air bag system.
The rear popping noise is only major issue, everything else ok. Love it otherwise.
The only reason I am after them is I am afraid anything that makes that type of loud noise will eventually fail and I believe there is a chance of loosing the tire/hub off the car if the hub assy fails. But someone can tell me differently if so.
GLuck
on the spline.
GLuck
