What to look for in a 04 Expy
My brother has a 3rd kid on the way and wants to trade a Grand Cherokee Laredo for an 04 Expy XLT with 15,000 miles on it. Problem is that he is 250 miles away and want's me to check it out for him. Now I'm somewhat familliar with the typical 01 Supercrew (see sig) problems that I should lookout for, but what are the typical hicks that 04 Expys have.
also a few questions:
Do all 04 Expys have a 5.4L?
Did the 04 Expy get a complete overhaul like the F150 Did in 04?
Do 04 XLT Expys have 17" Wheels?
What sections in the F150 Forums are closely related to the Expys (I can assume the "General Care and detailling" section is pretty much applicable
I told my brother to checkout this web site so he'll also be reading the replys.
Hey bro
Thanks guys in advance.
Dpostman
![Wink](https://www.f150online.com/forums/images/smilies/wink.gif)
Hey bro
![wave](https://www.f150online.com/forums/images/smilies/wavey.gif)
Dpostman
No, it got a complete overhaul in 03
yes, as do 03, 05 and 06
you can kinda group 03 and 04 together, and 05 and 06 together. The 05 and 06 got a updated instrument cluster too.
What to look for
Beside checking out everything out, problem areas been..
Door lock buzzing when being locked - solenoids seem to fail. Been through
couple of them
Rear end noise/leaking - in 2wd mode. In AWD or 4WD mode, hum from front axle. TSBs out for them, see if it's been fixed.
Snapping noise from rear half shaft area when going from D to R and back to D again with brakes on. Again TSB.
Squeal from front idler pulleys on engine when cold start (better if you can test when it's damp). Changed 3 of them so far.
I still have one power window that's a bit clunky.
GL
couple of them
GL
