98 Ford Expedition Brake Lights And Signal Do Not Work
Ok,,,,98 Ford Expedition, It Started Out With The Lft Rear Brake/signal Not Working. Tried Changing Fuses, All Good. Have Not Been Cited Yet For Lft Tail Light Not Working. Drove Like This For Several Months. Next, The Rt Rear Brake/signal Went Out. The Only Indication Of Brake Lighting I Have Is The Top Brake Light. Both Tail Brake/signal Are Not Working, However, The Parking Lights In The Rear Work Great And The Side Mirrors Signals And Front Headlights Signal Work. Any Sugestions??????
Sorry, I forgot to mention about the bulbs. Yes, I replaced both sides. I was reading my manual and I came up with a couple changes. First Idea was the stoplight/boo switch, but I was told if it was the boo switch is bad then the third brake light on top will not work. Next, I thought a might be a bad ground, but according to the electrical specs, the front/mirror lights share the same ground. After reading further on I came to a conclusion that a may be the multifunction switch. Basically, I'm asking if the MFS switch is going bad, will all the lights (Lft/Rt Front and mirror signal) be affected by it??????
