Lifting the Expedition
I would like to hear from anyone who has lifted their expedition. Either through suspension or body lifts. What are your impressions? Any driveline
vibration from lifting? It seems there are fairly limited options for these units
and not a lot of information on the kits. I don't have computer controlled suspension, but I do have AWD. These two factors seem to play into which kits you can use. Any insight would be appreciated. I want to run bigger tires to get better ground clearance for offroading. Thanks.
1999 Ford Expedition XLT
5.4 Liter
4R100 Trans
9.75 diff with 3.73 Limited Slip
5.4 Liter
4R100 Trans
Theres not a lot of limitation as you what is available, but there is a limitation as to how much of their wallet most are willing to part with. I have a friend that runs an offroad shop, and they have gone as far as to have customers get them to buy two kits for trucks where they don't have a kit for the desired height and ride quality, put them together to form one kit in the end. I have seen an epedition lifted high enough for 38's here where I live. If I see it again I'll shoot a picture.
i have lifted one expi eddie b, it was AWD but it had the air suspension we had to use two kits the front we used RCD and fabteck springs and mounts in the back, but that was becuase the air suspension, we got some vibration in the front so we put in a double cardian driveshaft and that took care of most of it he still gets just a tad of vibration, a body lift would be alittle harder than the truck just because the body bolts are alittle harder to get to but it shouldnt be that bad, i will be doing a body lift to the same expedition next month, i will let you know how it goes his is a 99 also here is a pic
Thanks for the posts people. I was considering just putting some spacers under
the coils for a bit of lift. Anyway, not sure how much you can go without getting into driveline issues on these. I have lifted a lot of jeeps and their limit is 3" without getting into driveline alterations. Even a 3" suspension lift needed a transfer case drop due to the limitations of the stock slip yoke style, rear shaft.
On this Expy I won't be doing any rock crawling or anything, I just want to run some
33's on the sucker for some extra clearance and appearance for light offroading.
