04 expy rear end problem
Originally Posted by 98Navi
Is it still under warranty? Usually, when they do a job, it has at least a 90 day warranty. If it wasn't properly shimmed it could cause an issue, or it could be unrelated. How many miles?
If you are out of warranty, I say this verifies the need to others for the xtended warranty!
the expy has 35k on the clock,,,ford did the service back in january
the clunk seems to go away when the the truck is hot,,,every morning,,my wife puts it in reverse to back out of the garage,,,and it clunks
I don't think its drive line, seems more like suspension.
me three - w/a '03
I have had my '03 in about 6 times and each time they
tighten the bolt on the axle to the hub area. Then the factory
came back with a "special formulation" locktite to use and that worked for several months but again crapped out.
I gave up on this about 2 years ago and doesn't seem to be getting worse and living with it. They even replaced the hub
and axle on one side and it came back after a few months.
GL
GL
