noise when steering
noise when steering
I have a problem with my 1998 Expedition. When the vehicle is idleing there is a high pitch sound which increases and decreases with engine speed. When I steer the pump makes a noise also. I check the fluid and it is to the top, when the vehicle is running I looked at the resorvoir and it looks like the fluid has bubbles in it for some reason. Are there any filters on the power steering or is my pump gone? Any help would be greatly appreciated.
Warren
Warren
Warren, Have you had any work done on the power steering system or suspension? How does the fluid smell? burned? Are you leaking fluid? I would get a stethescope and confirm that it is the pump that is making the sound. If you don't have a stethescope then a long piece of metal, like a long screw driver or extension, will work. If you recently had work done then you might have an air bubble in it. If not and it is the pump making the noise then I would assume the pump is going out.
Random thoughts. Good luck.
The two hoses at the bottom of the pumping go to the steering actuator or steering gear box. I can't remember the proper nomenclature but it actuates the pitman arm which turns your drag link and steering arm. There is no remote filter, just a pump with reservoir and steering gear box. The power steering pump is at the bottom right as you look at the bumper.
