Expedition with DVD and Factory Moonroof
Originally Posted by thompsdw
If someone has this option Expedition - could you help a fella out and look into the retracted Moonroof and tell me how the DVD player is braced below the moonroof?
I am about to do an install and I would like some ideas .... thanks in advance.
Mine is an '04 as well. I have the rear air system as well (complicates space above). Anything you and help with is greatly appreciated.
No, I went with an aftermarket player. The Panasonic I purchased suggests bracing to the roof steel in the vehicle. That is what I am trying to determine how to do below the moonroof. When you look there are two metal braces below the moonroof. One at the front of the air duct and one right by the moonroof opening. I am guessing that Ford either hangs their unit from the headliner or attaches somehow to those metal braces.
Thanks again!
Thanks again!
I had a look last night (in the dark, mind you), but I couldn't see how it was attached, or even how the cover on the OEM DVD system comes off.
I was able to push the headliner in independantly from the DVD player in a few spots, so I'm guessing they drilled through the headliner and into the metal braces. I wouldn't be at all surprised if they mounted the unit to both the metal braces that you speak off, the unit has a fairly large footprint between the airduct and the front of the roof opening. I'll have another look during daylight hours today or tomorrow, and can take some pictures if you like.
