Paint bubbling on tailgate
I just found some bubbling too, on our 04 NBX. Ford's crappy paint and NH's sometimes excessive use of road salts (or whatever they are today) makes for a bad combination.
Your S.O.L. on coverage for this, the rust portion of the warranty is for rust thru, as in holes. Not chips, bubbling, etc.
TSB
07-2-9 PAINT BUBBLES AROUND LIFTGATE TRIM
Publication Date: January 23, 2007
FORD: 2003-2006 Expedition
LINCOLN: 2003-2006 Navigator
ISSUE:
Some 2003-2006 Expedition and Navigator vehicles may experience paint bubbling or lifting around the trim area on the liftgate. This can occur when the trim part moves on the paint surface because of climate temp changes and/or owner operation. Overtime these trim parts can rub through the paint surface and cause corrosion to start developing between the aluminum gate and paint.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Paint resurfacing will be necessary to correct the paint bubbling concern.
Add Mylar tape to the backside edge of the following liftgate trim parts, the license plate bucket for Navigator (Figure 1) and the license lamp applique for Expedition (Figure 2). The Mylar tape will act as a friction barrier between the paint surface and the trim components.
Make sure that the backside of the trim pieces listed in Step 2 are clean of any contaminates. This can be done by wiping the surface with a 50% solution of isopropyl alcohol and water.
Apply the Mylar tape to the backside edge of the trim component. It may be necessary to trim the tape after its been applied for a clean fit.
After applying the Mylar tape, follow installation procedure for each part as listed in the appropriate Workshop Manual, Section 501.
PART NUMBER PART NAME
7L1Z-19E523-A Mylar Tape
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
DEALER CODING
BASIC PART NO. CONDITION CODE
78404C42 d7
Copyright © 2007 Ford Motor Company
ISSUE:
ACTION:
SERVICE PROCEDURE
WARRANTY STATUS:
DEALER CODING
78404C42 d7
I have this on our 04 EB as well. Just bubbled a bit right now, top right hand side by the registration plate trim. I suspect I'm SOL also, as my extended warranty is only the ExtraCare one. Let's hear another one for Ford quality...
On a side note, I didn't think the rear door was steel. I tried to stick a "Support Our Troops" magnet ribbon on it, and it wouldn't stick anywhere.
Originally Posted by *****
Actually, I'm over the 36,000. But they owe me anyway for the ***** tires they put on this thing.
It still shakes.
It still shakes.
