Blown Sub Woofer
I didn't have to remove the entire piece on my 97 EB... All you have to do is pry on the panel that covers it. The first time you remove it, it's pretty hard, but after that (when it isnt a virgin anymore
) it's a bit easier... I recommend using a very wide flat-head screwdriver, or you can by an interior panel remover... I saw a kit the other day at wal-mart for car stereo installation, it had a few tools including a really nice panel remove for about $15. I removed mine to disconnect the factory sub when I put aftermarket ones in... then to reconnect when I took the aftermarket ones out... now I'm getting ready to disconnect it again for aftermarket subs... I should probably make up my mind.
![Smilie](https://www.f150online.com/forums/images/smilies/smile.gif)
![Big Grin](https://www.f150online.com/forums/images/smilies/biggrin.gif)
Just start with the easiest and remove everything that gets in the way during the removal. You don't have to fully remove that panel, but if its your first time you're gonna be really pissed if you don't. Your hands will be battered and your patience tested. And just when you think its gonna come out, it doesn't
![Mad](https://www.f150online.com/forums/images/smilies/mad.gif)
These are the worded instructions from alldatapro. The pictures help alot but I don't have the time to copy them all to post them here. Good luck
Remove the liftgate door opening weather seal.
Remove the liftgate scuff plate.
If equipped, remove the third row seat.
Remove the rear header garnish trim panel.
Remove the rear door scuff plates.
Fold down the second row seat.
Remove the cross car scuff plate.
Remove the second row safety belt guide nut.
1 Lift the cover.
2 Remove the nut.
Remove the second row safety belt lower nut.
Remove the C-pillar trim panel.
Remove the rear door opening weather seal.
NOTE: Remove the upper attachments followed by the lower attachment and the lower rear hook.
If equipped, remove the third row safety belt guide.
1 Lift the cover.
2 Use Safety Belt Bolt Bit to remove the safety belt guide bolt.
3 Remove the third row safety belt guide.
Remove the D-pillar trim panel.
NOTE: Remove the lower hook attached to the quarter trim panel, followed by the top attachment, and then the lower rear attachment.
Remove the quarter trim panel.
1 Remove the screws and pin-type retainer.
2 Remove the quarter trim panel.
1 Lift the cover.
2 Remove the nut.
1 Lift the cover.
Well, I finally had some nice weather and spare time. I grabbed some beers and my tools and went to town. The 8" factory sub turned out to be a little bigger than the after market one. The mounting holes wouldn't line up properly so I had to make new ones. I just got some cheap $25 pyramid sub because I didn't think the factory amp would push a good sub properly. Anyone know what the power rating on the amp is?
